2 years and they've done nothing? Get on to OFGEM, screw your supplier they've had their chances and by the sound of it are messing you around.
I agree, if they've given you the runaround for that length of time I'd escalate it or I'd hand it to my lawyer to deal with them.
I would certainly get your meter changed immediately if its one of the old 'rotating disk' type, Are you sure your not looking at the small tenths wheel?. I recently got one of those little electric metering devices that are designed to scare you to death, and the first thing i noticed was how my electric fluctuated quitye a lot. With fridges, lights, standby's, and surprisingly, the enourmaous PS in my computer, the readings are all over the place. For my peace of mind i turned evrery swith off in the house. (youd be surprised at what is easy to miss in a house these days) Then i got a pen and paper and worked out what every appliance used individually. Thats when i was amazed how much my computer and assorted peripherals used. At least the, you will ahvean idea of whats going on. Good luck
You can do you own test with a known load eg 2kw electric heater should use 2 units of electricity in 1 hour , if your using 30 kw a day its more than a kilo watt per hour , i'm just reading my annual statement for a 3 bed semi its 11 kwh per day,with Gas fired space and water heating .
I did come across a job recently where the property had a dryer cabinet with an electric heater in the bottom and left it on 24/7 for 2 years because the switch wasn't identified it ran up £600 debt !
Make sure you know what all switches are for and if you can't identify them - switch them off one at a time until it becomes obvious what they are for. (check for critical equipment like freezer as you go )
Be careful with on neon indicators - just because the aren't lit doesnt mean the switch isnt in the on position the neon can fail.
If your on communal heating and hot water have you got your own "back up" immersion heater ? switch it off or it will heat the water in the cylinder and will cycle on and off as you draw hot water off thereby cooling any cylinder of stored hot water.
i am not sure if i posted this already, this morning i woke, never put on any lights, checked my efergy meter with a light from my lighter and it was reading 264kw, then after 10 minutes it dropped to 168 x so do not know how long it was showing 264 x
If it read 264 i'd be out of there - the heat from that the place would be on fire ! kettle = 2kw ? so 132 kettles ? suspect efergy meter is faulty ? or decimal point in wrong place maybe 2.64 ? Immersion heater is 3 kw
thanks, there is no back up what so ever, if the heating and hot water supply goes off we have to wait for them( council) to fix the problem, there is no storage heaters, no boilers no dryer cabinet, i did switch off my main supply via the main switch therefor nothing was working, i then put 1 switch on at a time in the main box then i plugged in 1 appliance (on) at a time to try and distinguish if it could be any of my appliances, this was not the case, also i do not have any old appliances, thank you for your advice x
i sure will do i have had such good advice from all of you, which i thank you all, xx as soon as i have anything to report i shall do so xx
I work for a social housing (council) we have our own energy advisers and like me electrical surveyors who would come out free , i suggest you contact your housing provider and escalate to councillor if they ignore you, the electricity meter is a contract between you and your supplier but you may well find your landlord will fight your corner - we certainly would i have regular battles with the suppliers re incorrectly wired supplies etc. You could also request your supplier installs a "check meter" ( or get council to do ) so you have two meters working at same time that way you could determine if there was a fault on the meter and then claim back the same proportion of what you have paid.
The thing is Brian, this has been going on for two years and the supplier have, from what I've made out from this, fobbed her off. Time to escalate I'd say
