Discuss Emergency Lighting in the Industrial Electricians' Talk area at ElectriciansForums.net
yeah this can be done in PVC/PVC. I would think you would have to use 3core and earth, so that the lights have a permanant supply and anoverride device, thats what we do in our small blocks of flats. have them run through a photocell sensor
I have used PVC/PVC before, with a key switch for testing. From memory the lighting circuit was on a seperate feed. Non maintained units installed.
Do you mean normal fluorescent fittings which also have a emergency backup in case of mains failure?
Emergency light should always be on the same circuit as the normal lights for the area that they cover as what use are they if the supply to the normal lights fail and the emergencies don't come on because their on a seperate circuit?
Yes mate mate, sorry thats whay I meant for the area they are covering. I didn't make it that bit clear - thanks!. :)
Reply to Emergency Lighting in the Industrial Electricians' Talk area at ElectriciansForums.net
I tested a self test emergency lighting with three gears .While testing 2 of the gear doesn't passed 3 hour test but 1 Did Wit the same battery ?Why?
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi folks, Can anyone recommend a reliable brand for emergency lighting bulkheads please? I have a job coming up to replace 30 odd units. I have...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Regarding emergency lighting, does a fire exit door require an emergency light above it or can you use a sticker that illuminates?
4K
