K
keith915
What colours do you guys use for live + Sw live? I've always used black switch live, brown permanent. The sparks I worked with today use black as permanent. All sleeved accordingly of course.
Discuss! :biggrin5:
Are we talking 3core and earth pvc, pvc cable here?? If so I tend to use black as a 4 pole klik uses the black core as permanent live with brown as switched live.
Yes I'm talking 3-core t+e. Is there any particular reason for using black as Permanent? The guys said today "that's just what it says on the destructions" . Is it to distinguish a cable as being used for an emergency light in the switch?
i use black as perm. L. because the you,ve got brown as switched L. same as on all the non emergency fittings.
oh dear, not much to discuss. I'm wrong, everyone else is right ! :oops:
It's good to challenge the 'norm' ...
it's not wrong, mate. either way is right, just that there's more of us than there is of you.LOL. which brings me to a point, related to this thread. as brown, black and grey are "phase colours", the same as red,yellow, and blue were in more sensible times, i fail to see the point of sleeving black and/or grey with brown. i know it's convention to do it, but fail to see the point. it's not like sleeving a blue if it's a switched live, is it?
V.true. If it's a phase colour, take it as being a phase/live/line conductor until sleeved otherwise.
Black sleeved as sw line for me also, always ID with sleeving to make sure no-ones confused coming in after me
Sent from my iPhone using Tapatalk
Same. Black is widely accepted as 'auxiliary', ie emergency feed. I subbied on a job where they wanted to use black as sw and brown as perm, using klik connectors, and of course everything went pear-shaped due to the colours crossing over.
It gets a bit confusing when you introduce PIR sensors though - they use brown for live in and black for switched (out), ie the other way around.
I did the Emer's on a large leisure Spa complex it paid to check EVERY lamp I replaced the standard seemed to be Yellow perm,red switched, but sometimes it was the other way and sometimes the blue was either N or switched,
Pict
Thats EXACTLY what I was taught (the theory behind using the black - same as the old yellow). And a good way to always remember it I've found.
