Basically a switch to disconnect the mains to test the batteries.what is a ctu??
Any idea of the wiring of this? Do I need a contactor or can I just use a ctu? ThanskBasically a switch to disconnect the mains to test the batteries.
How many emergency lights are there.Any idea of the wiring of this? Do I need a contactor or can I just use a ctu? Thansk
There’s only 6. I thought I might be able to just put a ctu there?How many emergency lights are there.
If they are all off one supply at the CU then a CTU would be the easiest.There’s only 6. I thought I might be able to just put a ctu there?
That’s what I was thinking? What do I do with the ctu? Take a feed from mcb to ctu then put cable going out to lights into ctu aswell? Never installed one beforeIf they are all off one supply at the CU then a CTU would be the easiest.
That is certainly one option with a wago for the neutral.That’s what I was thinking? What do I do with the ctu? Take a feed from mcb to ctu then put cable going out to lights into ctu aswell? Never installed one beforebeen stuck house bashing for too long!
Feed from mcb/rcbo to ctu then to light feed.That’s what I was thinking? What do I do with the ctu? Take a feed from mcb to ctu then put cable going out to lights into ctu aswell? Never installed one beforebeen stuck house bashing for too long!
Yeah they areAre these all connected to a dedicated circuit.
So I need to link them to the general lighting? How do I go about that?You can't do that with non maintained fittings they must operate upon failure of the local general lighting.
