Discuss estimating cable size in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
R
rasell
Is there a reliable way of estimating cable size when doing a visual inspection?
Sometimes cables can look the same, is it just a case of experience or is there a definite way of measuring and saying that is 6mm or 10mm?
Marc
Marc
only problem i have is when it comes to 4 / 6 mm besides that it comes with experience when assessing cable size.
I agree, Ian. I have come across two 2.5mm single solid core PVCs , where the insulating PVC makes one look like a 4mm! Also stranded cable can appear roughly one size bigger than it actually is, when comparing to solid core cables. Maybe it would be an idea to carry around a few cable cuttings with the sizes written on them and keep them in your testing kit box.. just a suggestion...
Not sure who makes em, but there is a measuring device that loops around the core and has a reading on the side, perhaps your wholesaler may know. i saw a spark with one recently on a job, but we have since moved on.
hello all, I raised this question in the inspection and testing section recently...
you can use verniers to measure the O/D of the cable to give you a guide for the csa of the cable. (this is not an exact science as so to speak but)
as you say the look of the core csa can be decieving..
You cannot just go by the width of the cable. Different manufacturers, different types of cable, old cables, new cables, solid, stranded, there are so many variables.
You just have to take them out and have a good look at the copper, not the insulated part.
Modern cables tend to have thinner insulation, so an old 6 might look like a new 10, and so on and so on.
For the larger sizes 10mm and up, I keep a piece of string with a crimp lug of every size going up to 300mm and at the board I take the live out and try each lug to see what fits. After checking it's dead of course!
To differentiate between 6 and ten I carry a yellow crimp connector. If it fits or nearly with a bit of wiggling it's a 6 if not its a 10. Hope this helps
Reply to estimating cable size in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
Hi guys. I was wondering what size cable and braker I'd need for an electric shower. Just out of intrest am I close in guessing as follows: The...
Looking to make a couple of commando ended extension cables with 4mm stranded cable. Many say that ferules should be used for this size cable...
Hi, Same project as detailed in my other post (I want to run shower cables to the CU whilst the kitchen ceiling is disturbed). I'm going to...
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
