Discuss EV charger installation. in the Electric Vehicles Advice Forum area at ElectriciansForums.net
If on a domestic property or one where the part p notification requirements apply then you will need to be in a scheme, pay building control to inspect it etc. as it requires notification to BC on completion.
no actual qualifications required unless you wish to install one under the olev scheme to get the £500 subsidy.
If you can comfortably install a new consumer unit then a ev charger is easy enough. likely need a rod too.
Reply to EV charger installation. in the Electric Vehicles Advice Forum area at ElectriciansForums.net
I have a client who wants an EV charger installed, charger TBC, but about 7KW, installed about 20m away from this installation. I've not done one...
I am an NICEIC contractor but I have never installed an Electric vehicle charger. I have watched all of the relevant NICEIC webinars (The wire) on...
Hi What the Maximum number of EV charge points that you can install in a Domestic system.
I’m wondering if anyone would be able to tell me if I have a looped supply in my property as I’m looking to install an EV charger.
On another forum for general EV chat this question comes up all the time. It's very common to install a charger taking the supply direct from the...
