Discuss Existing metal conduit in the UK Electrical Forum area at ElectriciansForums.net
A
Andy B
I`m rewiring a bungalow. There is existing metal conduits with rubber bungs on the ends for the switch drops. I`ve taken out the old wooden boxes and replaced with new metal boxes. I want to use the old conduits to run the new switch lines. What I want to know is do the conduits need earthing and if so how?
Andy
Why would they need earthing, they are just providing mechanical protection for the cables route to the switch!! You don't earth metal capping do you!!!
These were standard spec in council houses during the fifties....
just check that no numpty has boarded the attic and squashed the tops of the tubes. they usually came just above the tops of the ceiling joists.
No boarding in the loft. The tubes don`t come out much higher than the plaster boards. Its been really straight forward doing the lights today. Got most of them first and second fixed as well as the switches.
Andy
can always chuck in a couple of sockets FOC to compensate.
Reply to Existing metal conduit in the UK Electrical Forum area at ElectriciansForums.net
Have been asked to do remedials on an EICR that was carried out a year or so ago by another electrician. Curious to know what code you would give...
BMS installers have attended. After fitting the panel they also replaced the aged lighting in the boiler room with 6ft LED battens as instructed...
I'm getting an old fuse board upgraded in an office block. The electrician has just told me that most of the circuits don't have earth cables...
I’m planning a 240V welder circuit in a detached garage with a 100A sub panel. For the 160A or 180A output welders I’m looking at, the conductor...
