Discuss External metering enclosure in the UK Electrical Forum area at ElectriciansForums.net
Never had an issue with installing a SF in a metering enclosure as long as the equipment doesn't interfere with the cutout or meter.
If I remember correctly, the Lewden SF accepts upto 35sqmm! and is quite sturdy and relatively small.
The Wylex equivalent SF is often too big to fit in.
Those are nice switchfuses, except the terminal screws are too small for the terminals.
I just looked again, it really is pretty poor, small steel allen screws in a brass terminal. They should be large brass slotted screws in brass terminals. What garbage.
Reply to External metering enclosure in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
We had a new supply installed this week. DNO installed new cut out and fuse externally. Meter operator sent his engineer to move the meter in the...
On a new build site how/ why are people getting away with installing meter tails over 3metres in length and behind dot and dabbed walls with no...
Hello All, new to the forum. Would be grateful for advice on whether the following proposal is an acceptable solution or open to any suggestions...
5K
