Discuss Extractor fan relay for two independent light switches in the UK Electrical Forum area at ElectriciansForums.net
Id just get another inline fan probably as cheap as relays and enclosures
You can fit a relay in a backbox - and you'll most likely have one already for an isolation/maintenance switch. And it'll cost (if you pick sensibly) less than some of the switches people have been suggesting, and definitely less than an extra fan.
Like Simon47, Post #14 I was assuming all to be on same RCD protected circuit and maybe just a L & S/L at the switch! in an existing installation with loft access. Maybe it is being wired from scratch so is open to other options, but just re-read OP's post ........
from two different switched live lighting circuits.
TWO different circuits requires a different solution!
The OP only says it's two different S/L circuits - I would read that as two different S/Ls, but probably still on the same MCB.
If it is split across two different circuits, that's easy to handle - as I mentioned above, you just take the N/O contact of the relay to the permanent live of the circuit the fan is on. So the relay simple switches the fan between the switched live for that circuit, and to the permanent live for the same circuit when the light on the other circuit is turned on. The relay coil is connected to the lighting circuit that the fan isn't on - and it takes care of the isolation.
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan serves two bathrooms, just needs to be activated from two different switched live lighting circuits.
I'm aware double pole light switches could be used in this scenario but the light switches didn't pass wife test.
Anyone know of a dual input relay I could use for this purpose?
Meta
When you say double pole, did you mean, double pole in each switch for the bulb a jumper from each live to the fan and fan permanent neutral. With no relays ?.
Oh yes, the relay will hum when on. It's possible to add a couple of diodes so the coil operates on DC, and it's inductance will smooth out the half wave and eliminate the hum.
It's not a good idea to drive an AC relay coil with DC.
You are probably correct as OP doesn't make it clear how its installed, that was my original thinking in my post #6 which incidentally a circuit I had used before and didn't experience any humming (or perhaps drowned out by sound of fan)
That's it. But both lights must be on the same circuit.
It's quite common - some applications use a purpose designed DC coil, some use an AC coil and just feed it DC. Heatmiser do the latter in their UFH control/wiring centers.
Since it's only half wave, and relies on the coil inductance to maintain the current for over half of each cycle (so it's not smooth DC, and significantly less effective voltage than full-wave & smoothed), I doubt it's particularly bad for the coil.
Reply to Extractor fan relay for two independent light switches in the UK Electrical Forum area at ElectriciansForums.net
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
Hi brains trust, I am aware of typical wiring and legalities hence the questions. Looking for a wiring diagram to allow me to use a dual switch...
Hi all, I'm in the UK and have recently had a ducted extractor fan Mixflo 200W with timer fitted. The fan comes on with the pull cord and runs for...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
I'd like to find a timer switch, in a style that looks alright next to decora light switches, to control a bathroom fan. The bathroom fan...
