Discuss Extractor fans that don't need a fuse in the Electrical Tools and Products area at ElectriciansForums.net
SparkyChick
Staff member
Mod
Mentor
Supporter
Patron
Hi all,
I've been trying to find fans that don't require fusing down according to the instructions.
Can anyone recommend any please?
These are just replacements and I'm trying to keep the cost down for the customer so if I can avoid extra work to install fuses etc. I'd like to.
SC
Are they run off a 6A lighting circuit? I know it doesn't answer your question, but EDIT I think I misremembered - 3A fuse operates quicker than 6A MCB for overload currents - 7A would blow a 3A fuse in 0.05 seconds but would take 3600 for the 6A MCB to trip.
However although there's no need to follow the manufacturer's instructions, life is probably easier further down the line if you don't have to explain that.
The only time I fuse down a fan is if it’s spurred from a ring circuit. If it’s fed from a lighting circuit then it’s usually protected by a 6 amp mcb so as already said the mcb will most likely trip before the fuse ever blows
Greenwood
Sorry:)
But it’s daft this 3a fuse thing .....
And yes, it's a pain in the posterior. It's alright saying it's only guidance, but who amongst us fancies their chances arguing the ---- with someone in court? Personally, I don't, so I prefer to follow the MIs, it's just an excuse to off-load their responsibilities.
Hi - here's one I used a while back. It's Vent Axia, but I don't think all their 100mm models have their own internal fuse like this one, which is why I took a pic .
I took this 3A issue up with icon .... needless to say they wouldn’t budge ....... 6A MCB versus 3A 1362 ..... just goes to show how little manufacturers know .. and understand
I thought the same from memory but after checking it doesn't seem to apply to overload current. Do manufacturers specify a 1362 fuse for overload protection eg shorted windings as well?
Thanks chaps, got some choices :) I'm liking the S&P/Envirovent ones. Guess I'll just have to skip the part in the instructions about having an isolator with 3mm contact gap... that would be the main switch in the CU ;)
... Guess I'll just have to skip the part in the instructions about having an isolator with 3mm contact gap... ;)
Shouldn't be a problem, as fan isolators should meet this. Anything with the symbol nicely shown on the pic will be ok, so will plenty of others. It may be possible to find a 3 pole fan isolator for sale that doesn't meet the standards listed in Table 537.4 , but I hope not.
Reply to Extractor fans that don't need a fuse in the Electrical Tools and Products area at ElectriciansForums.net
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
Hi, Buying a replacement extractor fan. It falls into zone one with the room setup. Looking at two fans. One is rated zone 1 one is rated zone 2...
Hi i have these 3 red leds come on the extractor fan and it stopped working. Anyone knows how this can be resolved. Will a clean only suffice or...
