daveb
Hi all,
OK, so was sent to a job today for upgrading a kitchen. The existing mains was an older MEM board which the newer Eaton RCBO's wont fit. The only circuits being amended are the kitchen ring main (32 amp) and the lighting circuit (5 amp). The customer would not have been keen on changing out the whole board so I am fitting a new Hager 2 way board (40 amp main RCD switch). There is plenty length on the cables, so am able to pull them into the new board no problem. Rather than taking 16mm tails off of the incoming side to feed the new board, I am going to feed with with a 6mm twin and earth for the supply off of its own MCB in the MEM board. Ideally I would have liked to have the 2 way board run off of a 40 amp MCB but there is now a spare 32amp breaker seeing as I have now moved the kitchen ring into the new 2 way board.
Obviously the kitchen ring will not be pulling near 32 amps, neither will the lighting circuit be pulling near 6amps so when it comes to maximum demand I know I am well clear. As you know the old MEM breakers are not off the shelf items which is why I intend to use the old 32 amp MCB to feed the board.
Has anyone else come across this conundrum in the past? Some may question why a 32amp and 6 amp circuit is being fed from a 32amp MCB.
Would appreciate any comments. I have a tendency to overthink things even when I know they are safe! haha.
Cheers
Cheers
