K
Ken_Johnson
Property is a self contained flat conversion of a large house.
I am required to install a 'domestic' system to each flat along with a separate system for the communal area and have some questions.
1. Some folks have recommended Fike Twinflex Pro, others have recommended Aico. What's the general preference on here?
2. I have confirmed with the independent BCO and he states a Grade D system is sufficient and a panel isn't necessary. However, without a panel, how would the fire brigade know which alarm has gone off?
3. I understand LD2 states "A system incorporating detectors in all circulation spaces that form part of the escape routes from the premises, and in all rooms or areas that present a high risk of fire to occupants".. some of the flats have lobbies - does this mean a smoke detector in the lobby and the main lounge?
Many thanks.
Many thanks.
