Discuss Fire alarm question in the UK Electrical Forum area at ElectriciansForums.net
Highly
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell.
There are call points, smoke heads & sounders on each floor (3 floors), with 5 owned flats each with a heat/sounder installed in the their hallways linked to the same system.
Would this be classed as LD2 or LD3?
I think these grading can only be applied to individual dwellings.
From each flats point of view, LD3.
It sounds as the the system for the communal areas is L3.
What is the underlying issue?
Thanks for your reply.
The management company for the building asked for the fire alarm to be installed May 2021 along with emergency lighting for the communal area only. After completion they then came back to us in July 21 asking that we install a heat/sounder linked to the same system in every flat hallway for added protection and warning. We issued a cert for an LD3 system installed. They have now come to us saying that they have had a fire inspection which has failed due to it not being an LD2 system, (which apparently was on an updated spec...which nobody can seem to locate and we never saw). Some of the flats have their own internal smokes/heats. But due to it being a communal area job only we are a bit confused as to what can be done to make it LD2 as there are no high risk areas other than the incoming supply and landlords ccu. Or would relocating the hallway heat/sounder to each individual kitchen change the grading. (We have not yet seen the failed report).
Reply to Fire alarm question in the UK Electrical Forum area at ElectriciansForums.net
Hi, I need to extend a fire alarm, the panel is a CTEC CFP 2 zone one and currently it has a couple of apollo alarm sense sounder bases/heads on...
4K
I know this has been brought up before but as a QS for a housing association ,i have been asked my opinion on interpretation of the regulations...
Hello all, Firstly, I am not installing this myself and have several pros coming in to quote in the new year. A couple of years ago, most of the...
Having a bit of a mare at the moment with a small 2 story HMO (6 single rooms with shared kitchen) which was fitted relatively recently (2016 or...
Not come across this before, so would like some help, please. I went to install smokes and heat alarm (to new Scottish regs) in a fairly modern...
