Discuss Flickering led panel light on 3 phase in the UK Electrical Forum area at ElectriciansForums.net
I would have a guess at the initial start-up current of the 3 phase equipment is causing a volt drop that the electronics in the LED driver does not like.
Reply to Flickering led panel light on 3 phase in the UK Electrical Forum area at ElectriciansForums.net
I fitted a dimmer switch by daisy chaining the dimmer switch to a normal plug. The challenge is the light flickers at random intervals. If I take...
Done a job yesterday, remove old 12v halogens and replace with mains, gu10 downlights. Fitted some LED gu10's no issues. Got a call today saying...
Hi I have UPS 50KVA and the inverter output AC voltage is feeding a distribution panel 120/208 V 4 wires when I check UPS display it shows me...
Hello all- I hope this is the right place to ask this question. A few weeks ago the LED lights in the kitchen started flickering intermittently...
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
