Discuss Flood lights in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
if u do opt for making your own as long as u wire them in series you will be fine as people have said a 5 amp fuse in your plug top should be ample current but you will need heat resistance cable which isnt cheap so if the tripod works out cheaper then probs best option if suitable for your needs.........
If you wire them in series they will only half light as lamps are in series and not parallel
Hi guys
Im new here im currently in my first year on elec installation at college yale in wrexham to be precise.
Im wanting to wire 2 500watt floodlights but they need to be portable so i want them on a normal 13amp plug top. So I will obviously need to use flex so am i right in thinking that i need 1.5mm2 flex?? also what size fuse will i need to install in the plug top. Asuming it is ok to wire 2 500 watt lights like this i cant see why but im no expert.
Thanks Ashley still learning.
The code of practice for in service testing and inspection of electrical equipment which includes plug tops clearly states that not more than one flex shall be connected to a plug top and that the max flex csa shall be 1.5mm
Oh my, now I know why this country is going ---- up, maniac teachers are ruling -:)
Unless you missunderstood the q -;) I do hope the latter
Reply to Flood lights in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A
the situation is this: 8 x 24v rgbw flood lights for a garden, each fitting has power consumption of 45w. 3 lights into a 200w driver, another 3...
Hi.. Newby here.. I have a couple lights holders/bulbs on the end of a flex plugged into the mains 13Amp plug. I want to put an inline switch on...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
As the title says. But then I cut off a jst connection off one of the light strips and I can't get them to work together... the one strip is plug...
Im trying to make a Star Wars Prop for a course project where the dealine is comming up very fast in days and I need to do the report so really...
