Discuss fluke t120 in the Electrical Tools and Products area at ElectriciansForums.net
never had this problem and ive owned one for years now dont mean to sound stupid but have you got it set at the right setting ie volts when checking for voltage
A T120 is a voltage tester and that's all mate.What other settings have you got on your's:confused:
thats what i thought to. i figured it out though. it says in the manual that it has can trip the rcd if the probes are not placed on the terminals within 5 secs of each other. i think thats what was happening anyway
thefluke testers can be used as a positive test only, so i would say that when you are making a test while placing the posative on the lo side of the mcb, you are putting the negative lead on the nutral block for the opposite side of the split load, hence the trip
For voltage tests (L towards PE) in systems with RCD devices, the RCD may be
triggered. To avoid RCD tripping first test between L and N (approx. 5s). Immediately
afterwards testing L towards PE can be carried out without RCD tripping (not T140
VDE)
Get the instructions from Fluke website if you havent got any.
I have the T100 (same inst manual for all models) and it says, when testing voltage, test between L&N for a few seconds before testing L&E, this will prevent the RCD tripping. It is words to that effect anyway.
Cheers........Howard
Reply to fluke t120 in the Electrical Tools and Products area at ElectriciansForums.net
I saw a Fluke 1653B on Gumtree local to me being sold as faulty. Fault was stated as no continuity between 'N' and 'PE' ports on the resistance...
For sale Fluke T5-1000 with original belt pouch and Fluke voltage tracer pen ( it was a set ) this has never left the house just been sitting in...
Am absolutely gutted, my Fluke 1587 insulation tester appears it's had an unknown fatal incident. I was doing some testing a few days ago and was...
Hello, I don't know if I'm in the right place for this publication, I apologize first of all. I did a search, but I didn't find anything.... Does...
Could someone tell me if it is possible in fluke 1663/1664 to activate the option to carry out an insulation test without having the finger fixed...
