I come back from my travels after posting a thread about my CU change and I'm faced with this!! MDJ are you having a dig??
I have purposefully not looked at any other other posts... I really haven't!
Very hesitant about posting but I'm used to people calling me names so here goes..
1. Are all blanks covered? Including the small holes that are left after someone has replaced rewirables with MCB's?
2. Large junction box not accessible without removing the CU.
3. TNCS - Is it 16mm CPC.. looks like it but might be 10mm, also is it continuous.. looks like it must be broken as I cant see it going into either CU.
4. Main CU on left looks like it has tails going into neutral terminal block and a MCB??? I dont know if that is a big no no but it doesn't look good and I wonder if the MCB can take 16mm properly??
5. No isolation for whole system. Again I dont know if this is mandatory but I'd like to see a nice isolater that switches off everything.
6. Henly block might not be sealed on right hand side and haven't seen the seal go across like that before. Is it sealed?
7. Cant figure out what is going on with the main tails from meter. neutral to Henly and line disappears somewhere and then reappears as 2 reds into 2 CU's. Whats going on their? How is it split?
8. Bonding.. can only see 2 singles going into boards.. ?main earth and bonding. Is their gas? is it bonded? Is it 6mm?
I'm sure theres lots more thats glaringly obvious that I've missed but I cant look at it anymore and I dont know what that little consumer unit is doing between the RCD unit and left Main CU!!
I need lots more pictures and would have lots more questions for you MDJ!!??
What would I do as an inexperienced installer?
- I dont know if it definitely needs changing MDJ but I'd say 'yes' but thats just because its confusing me and I suspect this is a trick question in some way!!
- I wouldn't touch it because its too much for me.... so I would tell the customer that I am booked up for over a month due to my overwhelming demand!
Next time you have a job like that MDJ... please give me a call so I can watch!! :smiley2:
