Thts a y plan, mid position valve setup. I dont have any diagrams.im sure some guys will on here but if u look on googles images for y plan wiring diagram you will find loads
On a y plan system using a megaflow don't you have to wire a second shut off valve ( standard single port valve) to protect it incase the 2 port fails and calls for heat constantly
Yes chopper76 I believe this is new practice hence why people are moving away from 3 port valves and fitting 2 2 port valves instead easier for the installer all round. Normally you get electrical drawings with the cylinder too.
