Mar 7, 2011
Scotland
Can anyone help me I'm trying to wire up a new heating system any wiring diagram would be great.
System is: rhino savana condensing system boiler, megaflow cylinder, frost stat, danfoss FP programmer, zone valve for heating and same for water.
many thanks
Bluerob
Thts a y plan, mid position valve setup. I dont have any diagrams.im sure some guys will on here but if u look on googles images for y plan wiring diagram you will find loads
On a y plan system using a megaflow don't you have to wire a second shut off valve ( standard single port valve) to protect it incase the 2 port fails and calls for heat constantly
Yes chopper76 I believe this is new practice hence why people are moving away from 3 port valves and fitting 2 2 port valves instead easier for the installer all round. Normally you get electrical drawings with the cylinder too.
Scotland
Frost stat installation
Central Heating Systems
bluerob,
stuartcourt,
