Discuss Galv conduit in the UK Electrical Forum area at ElectriciansForums.net
sparks1234
Not something we normally get involved in installing, but, we have a long straight run of galv conduit to install (approx) 60 mtrs. Would this require any sort of expansion joint?
It was just the expansion thing I was wondering about, there are T boxes and lights all along the route.
It only dawned on me as the installation we are replacing has at approx every 20 mtrs what I can only describe as a humpback bridge and I was wondering if it was serving the same purpose
Cheers guys
Expansion joints are only generally required when the metal containment crosses a buildings expansion joint where the two building sections are expected to expand and contract....
You asked a question but forget to tell us the environment and temp' gradients changes etc ..... if its in the sun you may be surprised how hot the metal can get and not just expansion issues but ambient temp of cables rockets up... generally when you don't have these concerns take all the above advice as no need for expansion allowances
As a side note, its inside surely 2" trunking would be a lot more flexable solution
I really like working with galv.
It is much more satisfying to manufacture your own bends, sets etc.
Most of our work is in plantrooms so we use galv trunking, conduit or tray a lot
On most, if not all well specified projects, those inspection elbows/bends, Tees and in-line pull couplings on metal conduit containment systems are expressly forbidden. Apart from being a real pain to wire through, they can and will, shred the insulation from cables like a knife going through butter!! lol!!
Reply to Galv conduit in the UK Electrical Forum area at ElectriciansForums.net
At long last my wife is getting her new kitchen and the contractor will be running 10 or so new circuits from a new sub panel. The sub panel...
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
I’m planning a 240V welder circuit in a detached garage with a 100A sub panel. For the 160A or 180A output welders I’m looking at, the conductor...
Another thread asked about two circuits sharing a common multi-core cable and regulation 521.8.1 was mentioned. A friend of mine has inherited...
