Y
Yam man
hi newbie ere so go easy on me. We are getting new lazy spa hot tub and it's going to be semi permanent fitted into our outbuilding in a wetroom separated from my workshop.We have been advised to have new mini consumer unit fitted into our loft space fed from 12m max of 10mm t&e from unused mcb 40amp protected by 80amp 30ma rcd in main c/u. Then from the newly fitted unit with 63amp 30ma rcd using the 6 amp mcb for 3 light fittings and the 16 amp mcb to run 2.5 t&e through conduit in wall and supply 3x double switch sockets. There will be 1400w heater on most of cold days whilst I'm in working and the 2.3kw hot tub always running although once heated doesn't use as much. Then if I have compressor on that circuit and 2 cordless tool battery's on charge and music also laptop is used in there off mains power for car diagnostics upgrades reference etc (learnt my lesson when battery's depleted in middle of diagnostics repairs) This type of major full load wouldn't happen all time constantly but like to think ahead for future purposes and rather overthink and ask then regret it later. Sorry for the story but I want to make sure this all sound correct. It is a family members friend who will do the work. We have no main switch to turn mains power off how will we get this done? Thanks for any help advise.
