Is is going to be visible and accessible?... so I'm going to bond to the pipe in the floor void above the CU.
I'd definitely put the gas bond somewhere else if possible. Either further into the house or just outside it, rather than somewhere hard to access. I've bonded at the gas boiler, several meters into the house, where the pipe ran under an upstairs floor.Visible no because it's in a floor void... accessible... that would depend on the missing definition of accessible.
I will also agree with Handy sparks that it is also worthwhile positioning it where it is visible
Thinking plumber in the future, when he is looking for the bonding and its hidden or just more than 600mm from the meter,it sends them into waves of gas regs panics
It is most definitely accessible because you will be clamping it there
If nothing changes then it remains accessible
Just note its position on the certificate,I believe Nicy have a little box to make such a comment on theirs,if its good enough for nicy its good enough for Nipit
Two labels then... no, make that three.... one for the CU, one for the boiler and one for the gas meter cupboard.
New Toy?
NiceOne of these:-
Brother - Label Maker - https://www.tlc-direct.co.uk/Main_Index/Necessities_Index/Brother_Label_Maker/index.html
Absolutely awesome bit of kit. So much more professional than hand written scribblings and permanent marker. I have a bunch of customised labels for things like RCD test notice, periodic inspection notice, circuit schedule and stuff, but for those times when you need something a little out of the ordinary.
Loads of templates for things like patch panels, consumer units, cable flags and stuff.
