Discuss gas un the regs fred in the Business Related area at ElectriciansForums.net
M
MING
Reet. . . .this un crops up all the time just wanna get other views un interpretation fings on it . . . .GAS BOILERS UN CONTROLS IN DOMESTIC DWELLINGS. . .so wot qualifications do you need , do yer need to be Corgi registered, if you did not design the system can you wire in the boilers and the controls to that there system. . . . .way yer go:):):)
Think you'll find that CORGI regs only apply to the connection of the gas pipework. Anyone can do the connection of water pipework but not the gas only CORGI registered.
Ive heard that you need to have passed the 'water regs' now to touch any sort of plumbing....think its as adhered to as the wiring regs though by some....:rolleyes: not 100% on this but my nephew has taken a quick course and had to take this exam.
dont know a lot about CORGI, it is said you need it to touch gas, however I cant remember ever seeing a CORGI sticker on a Transco van.
Just a thought..............!
the water regs are wierd
anyone can plumb in pipework, but you need the water regs qual before you can run water through it!:confused:
as regards the original question, Part P requirements may apply (depending where it is), but no formal quals are 'required'
Reply to gas un the regs fred in the Business Related area at ElectriciansForums.net
Hi, I'm having a new boiler fitted in a new location. I need to provide power for the boiler which I'm looking to do myself. Boiler: Ideal Logic...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
Hi, We are designing and building cooking gas bottles with electronics controlled valves. These are for kids camping chalets. Its purely a...
I've seen a lot of people on here addressing the online qualifications for access training but not talking about the Apprenticeship aspect. I've...
