Discuss Gfci won’t work , wires are hot though. in the UK Electrical Forum area at ElectriciansForums.net
Mrclint
I need help, I’m trying to install a outside plug so I can charge my boat, I ran all the wire….checked wire outside and it works, once I shocked myself, second I put bare wires on heat gun and it came on. Everytime I wire plug up, I get nothing. I even had a second plug so I swapped them out and same result. I push the test and reset buttons nothing happens. I’m out of ideas can someone give me some pointers, thank you.
There is not enough information here to assist you, and the fact that you have taken some unsafe steps is of concern. If you are not sufficiently familiar with the correct procedure for tracing what appears to be a broken circuit, I would recommend engaging an electrician. Sorry that doesn't sound very helpful but we don't like to play guessing games with power circuits.
Reply to Gfci won’t work , wires are hot though. in the UK Electrical Forum area at ElectriciansForums.net
Hello and thank you for your time. In the picture, the 6/3 gauge NMD wire is running though the basement ceiling and out of the house into the...
I have a small power washer with a two-wire cord and GFCI plug. My outdoor and garage receptacles are on a "house GFCI" circuit, wired in series...
Replaced our old 240v hot tub with a new one, which also uses 240v for motors, heater, etc, and 120v for low amp LEDs and touch screen control...
Wiring to new dishwasher causes garbage disposal to stop working. I just installed a GE dishwasher and came across a problem with the...
