Discuss Glands for 1.5mm armoured cable in the Electrical Tools and Products area at ElectriciansForums.net
Hi,
I was wondering if anyone knew which size gland to use for a 1.5mm armoured cable. It has an outer diameter of 12-13mm.
I've used 20mm compression glands on hi tuff cable, but i remember the cable would go through.
So just wanted to make sure this time.
On the back of the gland packs is a chart that tells you what size cable the glands fit
Agreed on the 20S, although thats fine for 2 core and 3 core.... any more cores you'll need something bigger.
You cant use compression glands on armoured cable. The armour gland is brass, needs to grip the outer armour strands and be bonded to the earth.
Thanks for the replies, im going to be using 4 core and 3 core swa.
20S.
Three bloody words...
+1 for the Storm Glands if you have an exposed area. Also get the ones with the Earthing Nuts as a far better arrangement than the thin nut & banjo.
[automerge]1591445706[/automerge]
Come to think of it "Thin Nut & Banjo" sounds a lot like a deep-south musical act...
20S will do up to 7 core 1.5mm.
If an internal termination the BW will do but I prefer to use the external gland CW regardless.
As all stated above the Storm glands are the way forward and sure price will come down in time!
Reply to Glands for 1.5mm armoured cable in the Electrical Tools and Products area at ElectriciansForums.net
As the title says, I am looking for a recommendation for an enclosure and gland arrangement to electrically isolate or divorce the earth/armouring...
5K
Hi I have been in the electrical contracting industry all my working life 40 years and became a member of the NICEIC in 2006. During this time I...
Inspired by another thread, which I don't wish hi-jack. Can anyone recommend a decent, relatively low price punch down tool? I've had a cheap...
There are electrical engineers who just mutter the slogan "Safety is the top priority," and simply convey old and inaccurate Cable Tray Weight...
Hi All I would appreciate some help with a few questions here regarding cables sizing, I'm using the latest 18th edition, amendment 2. Q1...
