F
finn
well after 17yr ov been working for the local auth, its time too move on,and got a decent reduntantcy package;)
any how am in the process ov setting myself up on my own:confused:
had a look at a few jobs where the are asking for a certified contractor:confused:
does this mean i have to be NIC registered:confused:
i am a fully qaulified (16th) doing me part P end ov april
its scaring me a little:(
am i jumping in at the deepend,or is it not as hard as i think its going to be:confused:
Hi Finn,
Depends what they mean by 'certified' and what type of work you are looking at.
To be able to work in a residential dwellings you need to be registered to one of the self cert schemes.
Have a look here where all the scheme operators are listed and you can take your pick!
http://www.electriciansforums.net/e...ons/4299-competent-person-schemes-part-p.html
However, it will be fairly hard, work wise, because of the economic climate at the moment.
Good luck!
Hi finn,
second what jason says, but also we are working to the 17th now and have been for some time ;)
not sure if you would be able to register with the 16th :confused:
you are a brave man choosing this current climate for setting up on your own and i wish you the very best of luck ;)
Thanks for the replies lads:)
to tell the truth i have been subcontracting for the last few months for a Co who was niceic
and found the work not a problem whatsoever, and he was 17th and a picked it up ne bother:)
but now am on me own, the last job i looked at the building control will be wanting test compeltion forms
testing and filling the forms in isnt the problem
its what forms do i need to fill in without been niceic:confused:
as the lad i was subcontracting for would sign the forms off after i had filled them in;)
but with me not been NIC (YET) is the any other forms i can get/fill which will be ok for building control to pass:confused:
In a word, no.
In order to self certify you must belong to one of the scheme providers.
I suggest maybe you get booked on an update course and enroll on a scheme.
Until then, you will have to pay your LABC for them to so the inspection and tests on your installs.
The fees for this service range from are to area but is usually £100+ and is payable upfront.
In a word, no.
Until then, you will have to pay your LABC for them to so the inspection and ests on your installs.
LABC :confused:
does this mean my local certified contractor:confused:
which is the best scheme provider, i have been lookiing thru prevous posts and there's mixed views
i am in the northeast, dont no if it matters:confused:
or and thanks jason;)
local authority building control;)
all the schemes have their plus and minus points, you need to decide whats best for you.
my local authority lets you sign off work through them on green forms for £50 + vat but other areas charge from £100 + the thieving barstewards:eek:
going self employed
Business Related
finn,
flukey,
