Discuss Gu10 rubber ring Gu10 rubber ring in the Lighting Forum area at ElectriciansForums.net
Hi,
I am trying to get hold of some of the above (picture below), but I am struggling to find a supplier/retailer. Any ideas?
4184a306-701e-4fcf-83fb-a32028af4048
do you mean the suckers? sometimes they come with the fittings.
Wolfcraft WFC-5499000 GU10 Lamp Removal Tool - https://www.NoLinkingToThis/p/wolfcraft-wfc-5499000-gu10-lamp-removal-tool/6084k
No picture has come through in your post but, like Tel has said, this may be what you are after.
I wonder if he means the ring that jcc used to have in that goes on the bulb think it was to maintain accoustic barrier... If that is the case... I wouldnt worry about it
I don't think we'll ever find out. I feel like I've been used for my knowledge and then dumped. I'm not sure if I'll ever get over it and I may need counselling :(
Are they halogen or LED?
You're gonna struggle to find the exact flat gasket but you should be able to find a standard 50mm o-ring at maplin, farnell or RS maybe. I'd suggest silicon or viton would be better if it's available, especially if it's a halogen lamp.
This goes with @SparkyChick post on the ‘dodgy pics’ thread. I replaced IP65 downlights updating them and realised that these gaskets would be impossible to find so I’ve stored about 5 for ‘that rainy day’ - call me Steptoe and I’ll set my horse on you!
‘Any old iron. Any old iron’
Reply to Gu10 rubber ring Gu10 rubber ring in the Lighting Forum area at ElectriciansForums.net
Can I use multiple GU10 led lamps with their own PIR sensors in the same room? I have a row of existing lamps 600mm apart in a straight line & I...
Hi does anyone know where I can source any larger round grommets ? I will be drilling a hole in 100 × 100 trunking so guess around 75mm hole. I've...
Done a job yesterday, remove old 12v halogens and replace with mains, gu10 downlights. Fitted some LED gu10's no issues. Got a call today saying...
Hello. I am in the process of redecorating our bathroom. I ordered some GU10 led spotlights which came with the bulb socket and wiring. For some...
Hi I wanted some advice regarding which downlights company is better from ancell or forum? I have builders doing works in my house but I wanted...
