Discuss Hager meter kit fusing stupidity in the UK Electrical Forum area at ElectriciansForums.net
pc1966
Today we got our Hager meter kit for one of their 125A TPN boards. It has a little DIN rail fuse holder as the meter is powered right off the incoming isolator/RCD/etc without any MCB for protection (so the meter can't be switched off without everything going off, presumably so you don't cheat on any internal billing but that means).
So I opened it up to look at the fuses and was rather shocked to see a 0.5A glass LRC fuse! You know, the sort with a breaking capacity of 35A at 250V AC! This is off a 400V TPN board that could have a 10kA fault current at that point FFS!
Even replacing the fuse with a 20x5mm HRC fuse is only good to 1.5kA fault rating. What were the product designers thinking?!
Type-tested assembly...the fuse shatters but the box keeps the debris contained?
The meter protects the fuse?
Design specified HRC but stores had run out?
Counterfeit switchgear, meter module actually just contains sawdust?
Dunno, sounds carp anyway.
LOL it would probably all arc together across the fuse holders if there was a serous fault in the meter module, you could test it out to see what happens? Slydlok FTW!
On a similar theme, one well known gas boiler (cant remember which) used to have a fuse on both the line and neutral incoming connections. Could never work out why they thought that was a good idea.
Reply to Hager meter kit fusing stupidity in the UK Electrical Forum area at ElectriciansForums.net
Someone asked about abbreviations used here. So I tried to copy a list I made elsewhere: A/C Air Conditioning AC Alternating Current ACB...
5K
https://www.linkedin.com/pulse/can-you-really-test-circuit-6-dan-jackson-fiet incasee u dont use liked in heres the article in 2 posts An...
R
Hi all, I got given a past exam paper from the 2391 course tutor however it doesnt come with any answers so I thought id put the question and my...
20K
Flakey
F
