Discuss hardwiring cooker straight into 45 amp isolator in the UK Electrical Forum area at ElectriciansForums.net
If by cooker you mean oven, check the rating and if pre-flexed that your breaker is suitable - It's usually the hob (if electric) that pulls the most so that might want looking at - ask the guys here. In answer to your question, there's nothing 'wrong' with doing it as said above, just make sure it's suitable for the environment.
Nothing wrong with going straight from an Isolator to the cooker, however as said above if someone wants to disconnect it then they would need to whilst one side of the isolator was live or turn the mcb off. The benefit of the Cooker outlet plate is that someone can just switch off at the isolator and then disconnect.
i dont know the rating but the induction hob at home is on a 50amp breaker.
there are plenty of 7kw induction hobs on the market (standard 4 spot hob)
Cheers Shanky for giving an example of what I was getting at, being that the cooker (oven I think) if pre-flexed might not be suitable to hard wire to isolator depending on breaker
Why would being pre-flexed make it unsuitable for connection to an isolator?
Bearing in mind that the flex only needs to be sized according to the load on the end if it, not the full current rating of the OCPD.
Reply to hardwiring cooker straight into 45 amp isolator in the UK Electrical Forum area at ElectriciansForums.net
Is this ok? 32amp breaker with a 6mm wire leading to fused cooker switch. This then leads with 6mm cable to hardwire point. Can i hardwire 2 x...
OLDBOY
O
Hello All. I'm quite new to this game and gaining experience, but going well in the main. My customer wants to feed a Hob ( on island in centre...
A house we have just re-wired has one of these cooker points, Trouble is the kitchen wasn't supposed to have been touched by any trade but...
I have had my kitchen rewired ready for a new kitchen. I was originally going to have a gas cooker so a 3 pin 13a socket was left on the end of...
Hi, can someone please advise on where if anywhere I may acquire an adapter to duct out this old Elica cooker hood. The hole is 150mm x 90mm and I...
