Discuss Help, door catch required for external meter box in the UK Electrical Forum area at ElectriciansForums.net
Done that been there no worries, I ask a simple question, get 1 person's help, the rest nothing but derision:tongue: apart from a few well wishers:eek::rolleyes:
Why is it then, that with flat packed furniture you end up with surplus screws etc that you put in your man draw with all your other spares screws (which you never find a use for), but those flipping lights from B&Q my customers buy, come with the exact number of screws, which you enviably drop to the floor, never to be seen again! And none of those screws in the man draw fit those poxy lights.
I've looked into this myself and I'm not sure that you can purchase just the latches. I know you can get new doors, but the latches appears to be fixed with permanent fixings (some kind of rivet I believe).
But... having just gone googling...
Meter Box Spare Parts - https://www.meterboxesdirect.co.uk/meter-box-spares.html
They appear to have some latches.
I have used that link a few times, never replaced the lock itself before but have changed doors and hinges a few times. If they are anything to go by, it will be a doddle for a man of Pete's calibre.
From the link SC the latches look like they are held in place with one of those spring type clips? I may be wrong though....
It's Friday Middy chill man Chill, grab a drink or something.
:babyangel::bearface::koala::mouseface::pandaface::rose:
Or if you are bypassing the meter use this instead:
Smith & Locke Cam Locks 30mm 2 Pack - https://www.NoLinkingToThis/p/smith-locke-cam-locks-30mm-2-pack/6637p
Reply to Help, door catch required for external meter box in the UK Electrical Forum area at ElectriciansForums.net
What are peoples opinion's on this, pair of big old semi-detached houses (85 and 87) converted into apartments, dont think its a HMO although it...
Hope you're all well . I've had ring door bell 2nd generation hardwired for 1.5 yrs... it was connected to transformer which is connected to the...
3 Phase Smart Meter EDMI ES -30 B Install I have a question regarding the potential replacement of my existing EON supplied ELSTER A1140 3...
Hi, A lot about this fault confused me to be honest. So customer complained the doorbell was not working as intended. By that I mean the chime...
