... So, if I put my ammeter (10A, no fuse... she's a beaut!) onto the battery positive side to measure the current with the engine running, I shouldn't expect to see much more than with the engine off but the ignition on? Correct? If I see a huge draw, then something is definitely amiss.
Hi - Don't mean to teach you how to suck eggs, but if you put a 10A meter in series with the battery it will likely be fried when you start the motor. You need the clip on sort that can measure DC amps. They look like this -
Resting and charging voltages may well be clues .
resting 12.2 .. 12.8 ..even 13 if recently charged ..
Should be charging at 14.0 - 14.4 V typical ..
(if 16 -18 then that is cause attempting to over charge --and probably harming battery with lots of extra current )
.... Most car currents (ignition coils / Jammed-electric windows ) will be too much for your 10A range ... (especially charging current !)
Yep,there are methods of using that Tandy meter,even with it's 10A safety valve:)but,too involved for explanation,here.
You really need a clamp or clip type,which will give you current magnitude and direction,and are available fairly cheaply. I have an ancient Durite clip-on,which was my go-to jobby,as a kid...
You need to know size,and timing of any load,which may not be present,until a period after starting,but maybe not at "ignition on"position.
I have very recently had such an issue,on a large,modern horsebox,where the belt was being flung off,soon after starting,but not on every start-up.
This was due to a PITA split-charge relay,for the leisure batteries charge circuit,and the fact that the huge,18 tonne wagon's factory fitted alternator,was only 45A maximum output.
I feel a load heavy enough to tax your decent sized alternator,would not be hard to find :)
Thanks. Yeah, I wouldn't try to start it on a 10A meter! In the past I have put croc clips on the terminal and lead, then slid the lead off the terminal.
for testing alternators you can use your meters but there is a chance that you could damage the meters.
I highly recommend using a battery /alternator tester instead.
this type of meter is specifically designed for this use.
I got mine from a retired mechanic and have used it a lot.
