N
nickboaz
Hi all,
I am looking for some expert advice and knowledge to help get my head around an alternator load problem.
This has been on-going for about 18 months...
Vehicle summary;
1993 Mazda MX5 import.
Originally a 1.6 but I have put a 1.8 engine in from an early MK2 MX5.
I also fitted a UK spec battery at the same time.
The alternator is a used early mk1 1.8.
Engine harness and chassis harness essentially all original.
From all the MX5 knowledge I can harness, this should "work", and is certainly not an uncommon swap.
The symptoms;
Squealing alternator belt, and the alternator pulley gets very hot very quickly. If driven, the belt snaps in about 4-5 miles and displays signs of having been at high temperature.
If I disconnect the high tension cable from the alternator the problem goes away.
If I only disconnect the exciter wire and the charge light wire, the problem persists.
What I've done;
Started with belt tension - nothing made any difference.
Fitted brand new alternator. Still the same problem. Fitted another new alternator, and still the same.
I fitted another new battery. Initially this seemed to fix it, however quite quickly the symptoms returned.
I have checked the basics on the wiring - high resistance and shorts, continuity, and no obvious faults. I haven't touched any of the loom that might make me think there's an issue.
At this point, I don't have a good understanding of the loads and charge currents etc., hence coming on here.
The alternator is rated at 65A, and the battery is 425CCA and 46Ah.
My thinking is that too much is being asked of the alternator, and thus it is being retarded by excessive load, causing the belt to slip and get hot, and snap.
Please can anyone help me understand the load and rating relationship between the alternator and the battery? I feel convinced that there is a mis-match between the two parts. Or perhaps not?!
Thanks in advance.
Nick.
Vehicle summary;
The symptoms;
What I've done;
Thanks in advance.
Nick.
