- Feb 27, 2022
- 9
- 3
- 33
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- Australia
- What type of forum member are you?
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
I am making my first post here at this forum, and it will soon become obvious, but in line with the material I have recently seen on joining this forum, I AM NOT A QUALIFIED AUTO ELECTRICIAN(but hoping to be allowed to post in this sub-forum), just a reasonably experienced home mechanic who is more confident fixing mechanical issues, but less so with issues involving auto electrical components.
Are there any comments about the following short video?
He removes the positive/+ve battery terminal when the engine is running.
I remember that it was OK to do this on older cars, but AFAIK it was not to be done on modern cars as it might cause BIG problems with the ECU and/or alternator.
Comments welcome, particularly dealing with 2004 Mitsubishi Magna/ aka Diamante(USA).
There are comments either way in the comments attached to the video.
This is very confusing.
The reason I am asking this is that I am trying to find a cause for my older battery(4 years old 10 days ago) going flat with no obvious indications before complete failure, and the "like for like" replacement battery likewise going completely flat after 1 week.
The alternator/battery light has never illuminated at all when it should not do.
It illuminates prior to start, and extinguishes once started.
Terminals are tight.
Belt seems to be tight, with no slipping noises.
The brand of battery (both times) is the Australian made Century "Ultra High Performance 67 EF MF" model.
www.centurybatteries.com.au
Century Batteries have an excellent reputation in Australia.
It is the biggest size/capacity battery that will fit without modifications, and has 20% greater CCA(640) than original factory fitment.
I would appreciate some troubleshooting tips shortly, but I would appreciate if the contents of the video can be addressed and discussed comprehensively first.
Thanks.
67EF MF - Ultra Hi Performance Conventional car batteries | Century Batteries
67EF MF - Ultra Hi Performance Conventional car batteries. Special features: Carry Handles, Central Venting, Flame Arrestor, Made In Australia, Maintenance Free, Mud Rack, State of Charge Indicator.. Warranty: 40.
Thanks.
