Discuss Help on Deta Grid Connect Smart light switches in the DIY Electrical Advice area at ElectriciansForums.net
Azooma
Thanks for help in advance , I have 2 Deta grid connect switches im trying to install in hallway with led lights in ceiling
Issue
Wire switch 1 and 2 - Lights stay on in hallway - Buttons illuminate when pushed no change to the light stays on
Wire switch 2 down hall only - Light flashes and goes dull
Is it possible to switch my hallway lights on/off with either switch?
On switch 2 im questioning if there s a neutral at all and would adding one fix this , I have a light nearby that i could grab a neutral from that and run down to light switch 2?
This is the switch at front door
one switch controls a sensor light at door
other controls lights in hallway (On/Off)20201123_113533.jpg20201123_113537.jpg
The second switch is located down the hallway one switch controls light outside of house other turns hallway lights on off as well this is the wiring on this.20201123_113451.jpg
Regards
Steve
Reply to Help on Deta Grid Connect Smart light switches in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
Hi All, I am looking to install a Quinetic double gang in line receiver switch (QURS2W) in my hallway on the ground floor to control the lights...
Hi folks, I’m new to the forum and it’s this issue that lead me here. So first things first. I was looking to wire in a Smart Relay at the rose...
