Currently reading:
help...unknown heating system
Discuss help...unknown heating system in the Central Heating Systems area at ElectriciansForums.net
hi all
got a job to re install an existing heating system.
i have a danfloss three port valve,four wire brown,white-grey-orange-blue
no tank stat
room stat
controler with ho****er only or ho****er and heating
any ideas...ive wired a good few systems but not come across this.
ta all
vito
I assume you typed hot water & hot water + heating but forgot the space between words so the swear filter starred it out.
Sounds like a y plan but using the internal boiler thermostats to control temperature of hot water & heating.
and.....
my room stat has only a twin so no heating off!!
i have tested one wire on the valve a 148v though...is this a clue
someone must be able to shed some lite on this..
after all its rally just PLUMBING!
ha.
ps when i say brown,white i mean one wire is brown and white......one just blue.....one just orange and one just grey....is this any help..
wish it was a honeywell valve!
hi all
just to let you all know that it is sorted.
in the end it was just a y plan but because of the lack of a tank stat the mid positon wouldnt work!
fitted one and wired the heating through the hot water satisfied terminal on the tank stat and bingo.
ta all
vito
Reply to help...unknown heating system in the Central Heating Systems area at ElectriciansForums.net
