Discuss Help wiring cooker hood for cafe in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The datasheet gives the physical pinout of the connector, if one is fitted, which would allow you to confirm the functions of the colours. If yours does not have the connector, I think the sequence is as follows (by looking at the matching cable assembly)
1 / white
2 / red
3 / grey
4 / black
N / blue
1 / white
2 / red
3 / grey
4 / black
N / blue
Thanks, so when it comes to wiring the switch that’s what’s confusing, where is my twin and earth going and all 6 wires? I can’t get a wiring diagram of the switch anywhere
I think we've sussed the fan - the control switch selects one of four lines for the speed required. What the OP is stuck on now is how to wire a 4-position camswitch for 1P4W.
With the switch being marked 0-3, one speed (e.g. minimum) will have to be unused. It is likely to be something like:
White (speed 1) park in a Wago.
Red (speed 2) to switch terminal 1
Grey (speed 3) to switch terminal 3
Black (speed 4) to switch terminal 5
Blue (N) to incoming supply N.
Switch terminal 2 to incoming supply L
If they are not internally linked, it will be necessary to link terminals 2, 4 & 6 to extend the line to the other two contact sets.
Please check all of this with your meter before connecting up!!
Thankyou for your help, you have been very useful to me.
But check this carefully as I have made some assumptions such as the switch marking conventions. Check that in position 1, only 1-2 is closed, and in position 2, only 3-4 etc. Check that the four lines are in increasing order of resistance to N. Better still, keep looking for the proper MI's.
**I accept no liability for motor damage if there are errors!!**
Apparently the OP's switch only has 0-1-2-3
BTW, if the switch has another pole closed in all positions other than 0, that's for the neutral.
Suggestion of opening the connection cover is due to that being a popular location for wiring diagrams
don't tell that to my consultant.he'll want to open my skull to see how my brain is wired.
And also what about overload protection? imo you need it
As soon as you open the cover it will all become clear..
The numbers on the terminals will correspond with those on the wiring diagram for the selector switch
Reply to Help wiring cooker hood for cafe in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, can someone please advise on where if anywhere I may acquire an adapter to duct out this old Elica cooker hood. The hole is 150mm x 90mm and I...
  • Locked
Hi I also posted this on the DIY Electrical Advice - Electrical Appliances Forum My Kitchen has never had a cooker hood installed. Where the new...
Evening all, Currently 1st fixing new extension however the existing cooker hood duct which was on outside wall will now be part of new utility...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Hi I am looking for some help. My Rangemaster cooker hood stopped working sometime ago, I’ve stripped the hood down and degreased the hood. Ive...
