O
Ohm From Ohm
I have an 11 pin relay and base (Relpol R15-2013-23-5230) on which I need to switch 2 separate areas individually so that if either area is energised it prevents the other area being energised. The numbering on the base is as follows L to R.
Top Row 9/34 - 8/32 - 7/24 - 5/22 - 3/14 - 4/12
Bottom Row 10/A2 - 11/31 - 6/21 - 1/11 - 2/A1
Thanks in advance.
well. 10 and 2 are your coil. use a meter to find out what is open/closed when de-energised the energise and see what goes closed/open.
Help with 11 Pin Relay
Ohm From Ohm,
tazz,
