Discuss Help with adding a circuit breaker in the UK Electrical Forum area at ElectriciansForums.net
rube08
I finished framing my bathroom and wired an outlet and switch. I want to connect a 20 amp circuit breaker to the panel. I know the black hot wire is connected to the circuit breaker and it snaps into the panel. Does the ground and nuetral wire connect to the bar on the left? I see there is a mix of nuetral and white wires. Does it matter what order?
Rube08 yes you can hook both the white wire and the green wire to the same bar. That’s looks like the first panel after the power company
[automerge]1573598515[/automerge]
No it doesn’t matter in what order but I always hook up the ground first then the neutral and last is black
Reply to Help with adding a circuit breaker in the UK Electrical Forum area at ElectriciansForums.net
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
I’m planning a 240V welder circuit in a detached garage with a 100A sub panel. For the 160A or 180A output welders I’m looking at, the conductor...
The breaker pictured trips with nothing plugged into the circuit. It is able to be reset and stays reset for several days, but trips again. When...
Hi all. We have a 120v 20 amp circuit to an accessory dwelling with a run of about 75' of direct bury #12. The breaker keeps tripping even when...
