Discuss Help with led problem! in the UK Electrical Forum area at ElectriciansForums.net
hoppy
Hi
I have been to replace 2 bathroom wall lights from mr16 to 2 new led lights, however due to wiring issues, I have had to put the transformers in the loft. The lights will not
work and I believe it is due the the length of the existing 12v cables and the fact the new led lights do not draw enough current to make them
work. When I put my voltage testers across one of the transformers in the loft, the light it feeds works.
is there anything I can get to make these lights work, and would I fit it at the transformer or the fitting itself?
thanks
craig
Hi
thanks
craig
Hi
Transformers or drivers?
Cheers
Is there no way you can change them to GU10's? What sort of cable is sticking out of the wall, a piece of small 2 core flex or 1mm T&E and what CSA is it? How long is the run from loft to where the lights are? Plus, as above are you using a transformer or LED driver?
Hi
thanks
craig
What kind of voltage tester is it out of interest?
what location was the original transformer, have you come of the secondary of the transformer or have you come of the mains?
if you have come of the secondary how far have you extended the cabling ?
You do have a brilliant ability to remember everything DS! That's a compliment by the way. The series/parallel bit is obvious to me in this instance though.
I have a mate whom, like yourself, can recall detailed facts about everything he has pretty much ever read about/learned.
I don't think so, I would say I have more of an ability to refrain from posting on threads when I don't know the answers, which makes me appear more knowledgeable than people who post up guesses and wrong answers
Haha! Yeah defo a good policy to keep quiet sometimes. However your electrical knowledge, along with numerous other members on here, is excellent, and just shows how complicated electrics can be in my view. When I first started the CG 2330 approx 11 years ago, I never anticipated that the breadth and depth of electrical theory/practical work would keep me feeling like I know very little still! That is partly why I find forums like this can be fascinating.
Reply to Help with led problem! in the UK Electrical Forum area at ElectriciansForums.net
Hi, I have two LED light panels (like this: LED Panel 120x30cm - Varm hvid 3000K-40W -...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
I have a street light circuit on land I rent out. I need to replace 2 of the bulbs. 1 of them is an old Philips 55W SOX Plus, the other is a...
Hi everyone, I would like to use LED chips for DIY projects, to power them I would start from 12V drivers for LED strips. For some chips it is...
