spanner_monkey
- Reaction score
- 0
Hello,
I recently had my flat rewired and requested that all wires be chased into the walls. Because my walls are made of a very hard brick and to save on mess and noise, some of the power cables for plug sockets were run along the bottom surface of the walls, to be hidden by skirting boards.
As well as have all the electrics replaced, I took the opportunity to have a network installed and data cables were run with the power cables along the bottom of the wall. In some places the data cables are cable tied to the power cables.
Before I put new skirting boards in, I was going to put in speaker cable as well so, that I can have 7.1 sound in the living room.
In researching this, I have been told that I cannot put low voltage speaker cable next to high voltage power cables but, if that’s true then how come it’s ok to have the data cables in there?
I’ve no reason to think that my electrician has done a dodgy job. He has given me an EIC installation certificate and he has even asked me if he could use my property for his annual EIC check. The man from EIC came round and signed off his work with no issues.
So, can I put my speaker cables in there or not?
