J
Justin2211
Hello people I have a adt non monitored system I am after the master code and engineer code
Mine is playing about and the ex adt guy I have lost his number so can't get hold of him
and yes I know that no one is going to post on an open forum so if someone could help message me thanks
and it's not the default codes I need it's adt ones I think
There is no master code, but ADT have their own Engineer code, which you will be very lucky to find out.
The only solution here is a full NVM reset of the system
Yeah iv tried resetting by a few things iv seen online but they don't work don't really want to rip it out only been in 3 years
control panels are fairly cheap....a Texecom, ADE or any other alarm would replace without changing field wiring or detection.
Having been converted to fibre optic from copper telephone as everyone has to soon I have a comms fault message that requires engineer access for a permanent removal ……. but I only have the manager code .
ADT tell me they cannot supply the engineer code as they no longer hold records .
Local installers tell me they cannot obtain it or by pass the fault or even replace the control panel. They tell me my system is now totally defunct.
I have however found a by pass fix .
Type in your manager code .
Then hit
A … ENT …. ENT …. A … A … ENT
Your alarm is then on full set and working .
Unfortunately without an engineers code you will have to do this every time you want to set it. .
10 keys to hit instead or 1 but you haven’t needed to scrap your alarm !
Then hit
