Discuss Horstmann Radio Teleswitch in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
Just a question to see if anyone knows what the blue and orange button do on the radio teleswitch?
Changed over storage heaters to new ones, like for like swap and they have failed to come on during the night. Connections fine, fuses fine. It leads me back to this radio teleswitch and haven't contacted the supplier yet but hard to believe it's anyway a fault on their end considering it was working before. Wondering if these buttons have created the issue. The blue button swaps the screen from time to date and the orange button appears to do nothing when pressed. Will attach photo. Thanks for any help in advance
No load on display, have you energised the CU.? Because that tells me not.The sticker says it not a meter, I use them and they are 5 terminal meters for off peak, either E7 E10, evening weekends etc, and the blue button is for time date and readings. The no load status normally shows if the CU is not energized.
Orange button is for the meter engineer/installer.
When power to meter is re-energised the orange button when pushed will turn on the internal switches (off-peak etc) so that the engineer/installer can carry out tests,
It will turn on the off-peak supply/supplies so that the installer can do polarity tests etc
Orange button is deactivated after a short time
The only way to activate the button is to remove the main fuse, wait for display screen to clear then refit the main fuse
Reply to Horstmann Radio Teleswitch in the UK Electrical Forum area at ElectriciansForums.net
Hi, The details on the meter are. Telemeter Series K , Tariff Domestic E7 When I press the blue button it displays 5 screens : date ,time...
B
I've been scouring the internet trying to get some answers, and couldn't find any so I thought I'd ask the experts. :smilewinkgrin: Moved into a...
18K
evening. i have been too two houses today where there were faults on the storage heater systems . for instance i changed a fused spur unit which...
13K
K
B
Hi, I have a dual immersion boiler, with one immersion operating on E7. I no longer wish to use E7 after many problems with wrong switching...
5K
bertle
B
