Discuss How do I change a switched plug to always hot? in the UK Electrical Forum area at ElectriciansForums.net
U
upillai4444
I am as newbe DIY as it gets when it comes to electrical work.
Here is my issue at my home. I have a light switch which controls the recess lighting in the living room as well as all the plugs. A pretty poor design IMO especially since that room also acts as the TV/entertainment room. As of now I have to use an extension cord to the next room to use the always hot plug so I can watch TV when I want the lights off. The plug I would like to use in the circuit has two wires coming in, each with a ground, white, and black wire. In my research I thought I found a solution where I could break the connection between the two plugs in the socket by cutting the metal connector between them. When I opened everything up, it doesn't seem to match what I researched so here I am asking the experts.
I have attached 4 photos. 1 showing the inside of the box; 1 for each side showing each connector; 1 for the back of the plug.
I would be fine with one plug being always hot, and the other controlled by the switch. Is this something easy to take care of, or would I need to hire someone.
As for experience, I've replaced plugs and switched before.. so basically no experience. So far the only steps I know for this task is figure out which switch in the breaker box is for that rooms circuit... so have gotten no where.
Breaking the tab between the white conductors (neutrals) will just create an open circuit, don't break the tab. It looks like they are controlled by two switches and it is at the switches you need to do the alteration.
Thanks for the reply. There is only one switch that controls lights and plugs. I have included pictures of the switch. Seems three wires go to the switch, each containing a white, black and ground wire.
Make sure all the power is off and take the switch apart and tie the 2 black wires together then it will be hot all the time. Power off please
There are three black wires behind the switch; two connected to the same receptacle (upper right), and one connected to the upper left. The bottom right doesn't not have anything connected. I also don't want everything to be hot all the time, as I do not want my lights to be on 24/7.
Reply to How do I change a switched plug to always hot? in the UK Electrical Forum area at ElectriciansForums.net
have a set of lights that i would like to use plug over battery. have a few plugs and old sets with cables could Frankenstein together if doable...
The breaker pictured trips with nothing plugged into the circuit. It is able to be reset and stays reset for several days, but trips again. When...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
