B
Bul
May be a silly question but are rcbo's tested the same way as RCD's?
Many thanks, I've just never thought about it. Should test sheets then say RCD / RCBO tests?Yes same way.
which test sheets.Many thanks, I've just never thought about it. Should test sheets then say RCD / RCBO tests?
you treat it has MCB but not MCB but RCBO.
If you read the manufacturers leaflet that comes with them some require you to remove the earth fly lead prior to testing. i do it as a matter of course and have not actually checked to see if it affects results. I know with some it can affect loop impedance tests.
Have seen many a CU with them cut off mind!
yep , or is it 0010 nuwkie browns.*Bit drunk and can't recall whether it's 009 or 008
I was just thinking about a CU that only has rcbo's in it. Would each circuit be tested as an rcd. I've just never came across it and wanted to put it out for discussion.Why do you ask?
