1shortcircuit
Never seen one of these before but I'm sure plenty of you guys have. Please could someone be kind enough to tell me more about it:thumbsup
Would this be part of the distributors equipment or the consumers?
Many Thanks in advance
As its on the consumers side of the meter its your customers responsibilty.
Having a tired moment;)
This will need upgrading then as it would appear the 16mm twin and earth supplying the consumer unit upstairs is buried in the wall and I cannot see any evidence of mechanical protection.
It’s in the realm of the consumer.
It’s a 60 year old Bill 60A switch fuse. Despite what it looks like you will probably find the fuse isn’t a re-wireable but a TIA60A to BS88
Reactions: 2 people
1 x Socket radial supplying fridge and washing machine, 1 x lighting radial and 1 x ring final circuit.
My coffee cup is larger than the kettle currently in there lol.
These were the top makers of isolators and switchfuses The name Bill would go hand in hand with industrial and domestic equipment
They were fitted quite often with seperate units for sub main or power or lighting with usually one or two ways
Removing the cover to get at the fuse holder was often the case,there is an interlock mechanism to prevent them being opened live
Switching them on when they were open required that little bar to be depressed
The ones used on industrial sites were more usuially hinged at the top with the isolator handle on the side and with 2 thimbscrew retainers with the same feature of interlock,I believe they have been merged with mem
Reactions: 3 people
Bill/MEM have been merged a good while. Come under Eaton these days.
Des, are you a member of the Old Farts club?
I am not an old fart,Old farts are grumpy and forget things
Now come to think of it, I have just remembered that I was an old fart :mad2:
The last time I saw one of those being fitted was July 30th 1966, it was World cup final morning and the sparks were rushing to get finished so they could watch the match.
Reactions: 2 people
Interesting thread, in so much that if you were there just to change the consumer unit, how far would you need to go?
Would you need to replace the Bill for an RCD due to installation methods or would you leave it?
I mean after all, we are only responsible for the work we do.
Reactions: 1 person
1950s Bill, seen these as cartridge fuses & rewirable. This quite often involves wrapping 4 x 15 Amp strands of fuse wire across it with a bit of bell wire for the earth. Before all this new terminology, we just called them the main fuse.
There used to be fused Live & Neutral DBs in nice wooden cabinets with glass fronts. They were works of art, but the Neutral would blow & the Live would stay intact, switching off the circuit but leaving it lethal.
Reactions: 3 people
With regards to the RCD protection being added to replace the Bill. What do we think would be the outcome if someone was seriously injured as a result of the 16mm twin and earth being penetrated by someone drilling a hole to make a fixing in the wall?
Who would be liable? Previous Electricians? Home Owner? or Tradeperson for not taking precuations perhaps before commencing their work?
:thumbsup
theres loads of bill db's out there in old factories still,the thing i remember about the old stuff like that,before all the locking off and isolating,you had to be brave as a lion to plug one in live,if the fault was still there they dont half make a bang,im sure they had some sort of asbestos pad in too,
Reactions: 1 person
How old is this overcurrent protective device please?
Australia
1shortcircuit,
GLENNSPARK,
