- Reaction score
- 0
Hi
I have been trying to change an led gu10 bulb in a recessed spotlight in my hallway. On others there has been enough cable to hold the bulb and twist it to change, but this is too short, so I cant hold the connector still to twist the bulb.
I have tried pulled it with pliers, and also trying to twist it while using a screwdriver to hold the base in place with no success.
Any ideas? Will I need to take floorboard up above?
As you can see from the picture I have broken the plastic cover of the bulb trying to pull it.
Thanks in advance
Adam
Thanks in advance
Adam
