Discuss How to properly test an RCD in the UK Electrical Forum area at ElectriciansForums.net
.....and there's plenty of humour on this thread
Ben, forget your multifunction tester when it comes to RCD's. Use your multi meter, push the RCD button, and check that both poles have opened, and check the type and rating of the RCD. Job done, Regs complied with.
The only truly useful feature of the overpriced multifuction testers most of you buy is the Earth Loop Impedence tests, but then these can be done also with a multimeter and some calculation.
Hands up all those who know how to do that.
A thoroughly entertaining thread to read
Hi Southsea,
I realise this was just for fun but in the interests of not getting into a bad place with the other forum you've linked I'm going to close this thread and remove the link.
There's also a 'people in glass houses' saying and there's a few notable threads around this forum that don't show the UK electricians in a good light so I'd rather not start a ----for-tat kinda thing if possible.
Reply to How to properly test an RCD in the UK Electrical Forum area at ElectriciansForums.net
Apologies I know theres been a few threads about this and IR tests, but I'm still somewhat confused. The way I understood how an RCD works is it...
4K
Hi all, Got a client with a small barn workshop and caravan powered by a portable 230V 6kW petrol generator. (Loncin 8000D-A) . The original 32A...
4K
Is there a room in professional PAT testing for a business model other than 'per unit'? I ask because I've been giving this some thought. I've...
9K
https://www.linkedin.com/pulse/can-you-really-test-circuit-6-dan-jackson-fiet incasee u dont use liked in heres the article in 2 posts An...
Hey all, Downstairs lights are off. When you put the mcb on the rcd instantly trips. I've done an insulation resistance test and I have >20MOhm...
