Discuss how to remove a pir. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hello. Could anyone tell me how to remove this type of pir on an optima xm6 system. As shown in the attachment the pir has a hole underneath the cover. However, when checking this there appears to be no screw to release and remove the front cover . The pir appears to be attached to a bracket at the back. No screws showing at the back either. In the event i need to replace one of these is anyone familiar with it. How do you open the cover and remove it when replacing a faulty pir. Guessing, i think you either pull the body off the bracket which appears to be inserted in the back and is fixed to the ceiling or lever the front cover off with a screwdriver. I don't know the make as it is quite old. Anyone recognise it?
Remove the screw at the bottom and lift the front cover away.
Texecom is the make. small slotted driver in the bottom joint and twist. then code in panel/keypad to silence tamper alarm.
N.B. the PIR cover hooks on tabs at the top.
Reply to how to remove a pir. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi All, Might be a stupid question but I have about 30 of these smart+guard alarmed call point covers to deal with. All the batteries are dead...
Hello, Has anyone had any experience opening up a di-log dl9118? I can get the battery cover off, can remove the yellow rubber sleeve and undo...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
Hi, I am looking to convert a 2 way light into just control by single switch. I have searched and looked for similar questions here, and found a...
A friend of the family recently lost her husband to the big C so I need to be careful. Every small thing is sending her into tears so when her...
