_q12x_
Good morning minster @marconiGood morning. Some very helpful references - thank you. I was gathering together the components yesterday, many of which were well hidden in various drawers. Today is the day to start constructing my SCM.
You are gaining a good understanding of how the mains and parts of your own circuitry are interfering and disrupting the operation of your proximity switch.
The little video was useful. It does seem to work well but we both can see this circuit, when demonstrated, is not near any unearthed mains equipment or mains wiring which would interfere or disrupt its operation, which your is near.
Indeed, mine is a special case, a challenge and a pain in my but.
What I've tried today.
My other friend asked my why I dont keep the pot in the SCM, as the original movie shows. And I give him a vague response at that time, "because it works without it". And today I tested both with a 10k and 1k pot, and both just shut off completely the entire circuit. Like a shunt. Nothing lit. Just all dead. When I disconected the pot, everything got to the normal. And Im talking experimenting on the wall directly. What a pain in my back from my awkward position on it to solder those fine wires, and not to hang some other wires.
Another good idea was to work directly on the wall and I did it for a couple of hours of switching back and forth components and wires. In the end, the conclusion, all the filtering we are adding, is kind of helping but not really. I removed all the caps and resistors from the signal wire in the end.
Next, I changed the signal wire with a coaxial wire, very small diameter one. And it worked normal as before with the copper wire, but when I put the ground to the mesh of the coaxial, everything got lit to maximum. And also nothing responded. Aaah what a disappointment. I noticed that signal wire is very sensitive, pretty much like my antena, not quite, but too sensitive anyway. So I wanted to shield that sensitivity. But it didnt work.
I noticed something else very important. The white led from the SCM is ON all the time. It is off while everything is off. When I activated to OFF mode, and also the light in my room is off as well. BUT, when I switch to ON mode, that white led should get On when my hand is near it, which it does, but immediately as I retract my hand from it, it should go off. Instead remains ON all the time. I didn't pay attention to this detail before. Im sure it was the same in my previews videos and attempts. SO in a word, no matter how many "smart" filtering we will add to the signal wire or to the rails of SCM, he is functioning normal !!! but the source of interference is outside of it and is keeping it open. That's the reality. We must find that source and neutralize it.
Small modifications : I eliminated the 1000uF because they were delaying too much the normal operation of the entire board circuit. I also replace one to 100uF but then I realized its not really necessary. Sorry to be against the "normality" but hear my reasoning : If on the table is working flawlessly, then is in very good condition and very well made so far. The only problem is the wall itself. Well, the 50hz that I suspect from inside him. I tested all the caps so far and no real visible improvement from them. So I took them off. They were test subjects and nothing more.
What else? Im so tired of it not working. Its the truth.
