Hi All.
What is the best/preferred method when connecting 20mm conduit to a back box of a socket on an outside wall ?
I am connecting a BG Weatherproof Storm DP 13A socket to an outside wall, fed from socket directly behind the socket from the kitchen.
Would using a 20mm female or male adaptor with a locknut in conjuction with a sealing washer either nylon or neoprene be acceptable, eg IP rating ?
Or would using a 20mm flange coupler with sealing washer, be the only option ? I have already posted a question in regards to a PVC flange coupler, previously on the forum.
Any advice or recommendations will be kindly appreciated.
Or something similar to this :
A 15mm Push Fit Tank Connector.
CMP 20mm M20 White Entry Thread Seal 2mm Thickness (Sold in 1's)
- Part Code: 20ETS2
- Stock Code: 0007-0993
- To maintain the Ingress Protection rating between the equipment and the Cable Gland
- The need for a sealing washer will depend on the ingress protection rating, code of protection of the equipment and the type of entry holes available within that equipment
- The CMP metric Entry Thread Sealing Washers are produced in 2mm thick white nylon as standard which are recommended and meet the specified requirements of Shell’s Offshore operations.
